General cost to add 22's to a stockfloored dually?
delock
hey guys,
i want to add 22's to my dually. What is the general cost for doing this and how much work?
lockone's avatar
lockone
I sell the 10 lugs 22s for 459 ea. that includes the wheel, center caps, lug covers, polishing, milling, and shipping. Adapters will run 890 shipped to your door. Tires will vary depending on the size and brands you prefer.
delock
Check my gallery,
do u think I will have to do more work to the truck?
delock
Check my gallery,
lockone's avatar
lockone
What rearend do you have in the truck and how much is it B/D. Mine has a C-30 Bread truck rearend in it and the front fenders have been sectioned and raised 3" but that is to clear 24s. 22s will be fine with factory fenders. I belive the only thing you will have to do is swap or shorten you rearend, or widen your dually fenders.
bdydrped's avatar
bdydrped
unless anything changes that truck still has the stock rear end in it.... so you will have to do what ^ he said... and you will also have to tub your firewall some to keep em from rubbing
btw what up man this is jimmy.
lockone's avatar
lockone
Along with the shorter rearend I also moved the whole cab back 1 inch to cut down on the size tub needed for my 24s.
pig rig's avatar
pig rig
how much are you shorting the rear ends
lockone's avatar
lockone
I don't shorten the rearends I swap them with a box style truck rearend out of a C-30 bread truck. These are a total of 4 inches shorter that stock.
pig rig's avatar
pig rig
it would be quicker to chop it down. i need to go through mine any way. also you said something about the front end far as the cab how much do I need to cut out of it
