Page 1 of 3
Mazda Trucks \  2 link 92 ex-cab
2 link 92 ex-cab
Mazda Trucks Make Specific
views 336
replies 23
following 20
mets3000   +1y
I'm only going to go up and down, no side to side. So I want to do a two link and pan hard bar. Question? Can I use the front leaf spring shakle to mount the front of links to and keep the pinion angle right? This is a daily driver that I cannot keep out of comission. I have to have everything ready to go and get it done on the weekend so I can get to work on monday. Simple but effective is the key here. UP/DOWN no binding no bells and whistles. Just clean and get the job done. Come on I know you guys have the answers.
fatboysS1O   +1y
Edited: 12/19/2006 7:52:56 PM by fatboysS1O
a lot of people are gunna tell you not to do the 2 link for many different reasons. also i dont recommend you making your mini your daily. ive been doing that for about a year now and no matter how well you maintain its gunna have its problems. stuck or frozen valves, burnt up relays, etc,etc,etc. not trying to get you down buddy just trying to tell you from experience. so you can make it a daily just expect to be calling in to work late a lot a canceling plans and lot.
dssur   +1y
1st: It doesnt matter if you dont want "side to side", your axle needs to articulate over bumps or when pulling in a sloped driveway. If you two link it, and the right wheel runs over a bump, the left wheel will hop. If you pull into a slanted driveway, the outside wheel will come off the ground and you will be stuck because mazdas have open rear axles. (the lifted wheel will just spin, the one on the ground will do nothing)
2nd: The pinion angle will only be right in one spot. If you set it right at ride height, it will be wrong at full drop. If you set it right at full drop, it will be wrong at ride height. If you set it at either of those, forget about lifting all the way up, it will be wrong. Its because the two link makes the axle follow an arc, with a 3 or 4 link the upper and lower bars work together to hold the pinion angle.
3rd: when you use a two link, usually you want the front mounting position to be at about the middle of the range of lift/drop. If you use the factory perches, it will be really low. This means the axle is going to move back and forth (closer/further from the trans) a lot as it goes up and down, and the wheel will move back and forth in the wheelwell and not be centered. It also means the driveshaft will be moving back and forth that same amount, which plays hell with the carrier bearing. Because the mazda leaf perches are so close to the axle, the links will be really short, wheich means this problem will be worse.
4th: On a mazda, the front leaf perches hang lower than the frame, so your two link bars will too. You wont lay out, and if you drag you will drag two link bars.
My personal opinion is that two link users are lazy. That doesnt have anything to do with what I just said above though. I gave you very salient reasons why you shouldnt. If you are taking the time to do it, my opinion is also that you should do it right. Moving the gas tank is a walk in the park compared to bagging a truck, I dont really understand why everyone tries to avoid it.
TUCKINTEMPO   +1y
russd, you should have used a 4 for your "r" in your barcode, oh yeah boo to two links!
balcar   +1y
2 links are pooooo....
down2earthdawg   +1y
I agree with 2 links are shitty your best bet is to mono lief it and bag over axle
you wont lay out but its alot safer then the 2 link
mmautoworks   +1y
A MONO LEAF IS GOING TO GIVE YOU ALOT OF AXLE TWIST ESSPECILLY UNDER ANY ACCELERATION YHERE ARE TONS OF PEOPLE RUNNING TWO LINKS AND THEY DO WORK I HAVE USED THEM SEVERAL TIMES BUT IN ORDER TO GIVE YOU PROPER AXLE ARTCULATION AND PROPER DRIVETRAIN ALIGEMENT A FOUR LINK (3 LINK) OF SOME TYPE IS GOING TO BE YOUR BEST OPTION. DO SOME RESEARCH AND DO IT THE WAY THAT IS BEST THE FIRST TIME AND YOU WILL BE ALOT HAPPIER
balcar   +1y
axle twist is not a issue with a whopping 95 HP. haha
dssur   +1y
95?! You must be running a 50 shot of nitrous!
TwistedMinis   +1y
Do a reverse 2 link, you can make it plenty long. Lol.
