'02 F150 baggin ideas
16 following
F
magnum7579
I have a '03 F150 SC I plan on baggin this winter and need help getting started. Looking to see what is the biggest size bag for the front and rear you can fit. I also need mounting ideas for the rear since the leafs are staying for now. I plan on using airbags or Shockwaves for the front.
groundedbigbody's avatar
groundedbigbody
Edited: 12/21/2006 5:37:19 PM by groundedbigbody
bags and cups up front and lower control arms , for the rear use the kp kit (6 link) are triangulated 4 lnk like mine but with that you have to move are mod the gas tank . for front bag i would use slam 6" bags out back nothing smaller than the 7"out back
magnum7579
cool thanks. any idea on what kinda lbs bag (2500 lbs or 2600lbs)?
jmn444's avatar
jmn444
slam 6" is same as a 2500lb, and 7 is a 2600 size...
don't hack it w/ the leafs, save up for that kp six link, it's bad ass and you'll get tons of lift too.
magnum7579
ok so any ideas on how much I'll need to notch the frame to lay on 20's? I'm not wanting to cut up my bed floor.
lowfrontier03
Edited: 12/24/2006 9:12:33 AM by chevy1996s10truk
if you dont do a monster notch (involves cutting the bed floor) it wont lay
Bdierks
Dang, i posted in here twice yesturday and it wasnt working. So this is a test........
Bdierks
Ok great, here is what i posted yesturday...
the biggest size bag for the front depends on how much cutting you want to do. the firestones 2600's will rub if you just have a bag cup in use with your stock spring cup. the slam 7 bags will for sure rub. the best way is to remove your stock spring cup and build an upper bag mount that is welded to the frame. but for the slam 7 and the stone 2600's, you will still need to notch out the frame a bit in order to have room around the bag, and not rub. what i did was, removed the stock spring mount, and made a new one for my bags. and i didnt want to cut out the frame to clear the big bags, mainly because i was trying to get it done intime of a show. So i ordered a pair of the slam 6's. But, if you use the slam 6's, you will need to have a lot more presure inorder to get the lift you will need. i just got a bigger presure switch (200 psi) and that was that. hope that helps. let me know if you need any more help. LATE..
Bdierks
And for out back for your notch, make it big enough to lay on 22's. because, trust me later on you may want to upgrade, then you wont need to redo your back setup. I am lookin to upgrade mine to 22's and am sure glad i made my notch big enough.
magnum7579
well i think cutting into my bed is not an option. I'll just have to live with the biggest notch i can fit. i just had the bed sprayed w/a liner. i was hoping not to have to modify much on my front end. if cutting or making new bag mounts is what has to be done i might look into shockwaves for better fitment
