Ford Trucks \  toyo front clip???
toyo front clip???
Ford Trucks Make Specific
views 340
replies 19
following 9
CrazyScissors666   +1y
hey, ok i have a 94 ranger bag i wanting to do without the camber on the the front what year in the toyo front clip do u need to have?? and after u cut your ibeams crap off can u bolt on the toyo front clip to your frame or would u have to weld it to it and would this change u lug pattern on your wheels
Gump1986   +1y
i know that 88-94 yota clips will work. you will need to get the clip from firewall forward.
the toyota lug pattern is the same as a ranger.
bodydropped85   +1y
you have to weld the clip on. best spot to cut it is right behind the coresupport and right behind the spring pocket on the ranger.
is it pretty hard to do??? and all u have to do is buy the airbag brackets for the toyo??? how much will it run for the clip like 200 to 300 at a junkyard i don't want to get into to much money i just got my bags and they cost enough lol
Sprk Sho   +1y
I think I can get you the clip for $150 if your interested.
Gump1986   +1y
you should be able to get a clip for between $150 and $200.
check out www.gravity-werx.com for the front brackets. mike sells some awesome parts.
also, depending on what size wheel/tire combo you are running, you might need to get some drop spindles.
i got on 18inch on the wheels and i'm running 225/40r18 on the tires
does anyone know a site that tells you step by step on all u need to do to switch out the ibeams step-up for the toyo front clip step-up for the ranger it would help out alot thanks
racinjason68   +1y
why would you not want all the camber? I have hella camber with beams and love it. Good luck with the frame clip'n.
bodydropped85   +1y
i havnt seen a step by step. its really extensive process but worht it IMO. if your just going to stick w/ 18s, then i beams will work but over that it pretty much needs a yota clip to be driveable and b/d. the camber is nice, tire wear and lift is not.
