Page 1 of 3
Air Ride Suspensions \  welding
welding
Air Ride Suspensions Q & A
views 413
replies 25
following 19
greenranger 23   +1y
do i need a 220v mig welder can i use a 110v mig welder to weld a 4 link and bag brackets
bdydrp97s10   +1y
i used a 110 and the welds hold just fine...keep in mind to make several passes though
dragnbody   +1y
What size 110? Ive just got an hobart handler 145 and it works fine. You have to go slower and it dosnt have the duty cycle like a 220, but it gets the job done. I dont weld anything bigger than 1/4 in. with it.
greenranger 23   +1y
does it need to be gas assisted
jdozier1279   +1y
gas YES.....w/o looks like ass.....i also have a 110 and its done just fine....as noted. i also dont weld anything over 1/4 inch. anything under you should get good penitration depending on the welder
lo75lux   +1y
the bag brackets on my truck were done with a 110 lincoln,no gas.still on goin on a year
LOWEST1   +1y
It helps to preheat the metal to get the best penetration when using a 110 on 1/4. But it can get the job done.
greenranger 23   +1y
i don't think any thing is 1/4 thick
thebagged1   +1y
cant beat a millermatic 175!
MagicMikey   +1y
i know many people that use gas with a good 110v welder and they dont have any problems. but i went and got the millermatic 210 (220-230v) weld to be safe. the millermattic 175 is basicaly the same thing just packaged different.
