Mini Truckin General \  PTC vs. Compression
PTC vs. Compression
views 310
replies 12
following 10
laydsuzu   +1y
Which is better? I want to convert more of my truck to PTC, some of my truck already has them. SD has a good selection, but anywhere else for the same price or cheaper, what about locally? Also, I'm thinking about disconnecting my tank pressure gauge inside the cab so I can run higher pressure without blowing that gauge. what do ya'll think? The guy from SD told me their fittings are rating max at 1100 psi. I want to try to run at least 350 just to see what will happen. Also, my truck is on stands for a while till I get them, and its already got cobwebs under it and on the inside somehow
bodydropped   +1y
only way to run 350 scotty is to be on the bottle ur comps will never be able to reach that high but waylon told me to run ptc on my truck but all the stuff i have was all comp fittings
fatboysS1O   +1y
i like PTC, piss on compression fittings.
www.gravity-werx.com sells fittings also. and if you have a local Parker Hannifin Store try there thats where i get all my fittings.
dirkbelt   +1y
i just saw u saturday night at 11th stree cruise queer.them bitches can build a web in a couple hours anyways.and what are u gona do about the bags cause im pretty sure they wont last long.
laydsuzu   +1y
well of course I have a bottle tj de de de! Well I blew a line on the way home goin 70 mph. im tired of messing with compression fittings when it comes to air line. Yeah, Imma order some new bags real soon too, but I want some PTC fittings soon. Idk when Imma have time to get them though. I get paid tomorrow, no tellin when imma be off again
eks10BDRG-N   +1y
spend the money and buy a roll of type L copper and the fittings from ekstensive. there is a place on ebay where you can order, T's, 90's and unions all 1/2 inch with free shipping. my truck has been bagged since 01 and the last 3 years have been with copper and no major problems
eks10BDRG-N   +1y
Edited: 5/16/2007 2:28:20 PM by eks10BDRG-N
this is a quick list of fittings on my truck. 4)Ts, 4)90s, 5)straights, 1)bulkhead fitting, 2)1/2 to 1/4 reducers and 1)90 union
laydsuzu   +1y
wow, I have a million fittings on my truck doesn't leak as bad as I thought either. imma try to name all of mine off the top of my head. (2)four ways (5)tees (5)nipples, i give up.....my head hurts
eks10BDRG-N   +1y
well those are my ptc fittings,
it all depends on how your system is set up. ive redone trucks in copper where i pulled out about 45ft of dot airline, bought a 60ft of copper and only used about 30ft, the customer was happy little to no leaks...
laydoutb26   +1y
i am buying all ptc fittings on my B... i buy locally, all Camozzi fittings... the best in the industry... they have a teflon ring inside it...
