Page 1 of 3
Air Ride Suspensions \  grade 8 bolts
grade 8 bolts
Air Ride Suspensions Q & A
views 356
replies 26
following 16
simple-pleasurez   +1y
i need bolts for my 4 link. At the hardware store they have grade 8 bolts but they arent the nylon locking bolts. will these still work? its for the pieces that bolt on to my frame. and yeah i know to use loctite. thanks
no1lowr   +1y
just use those bolts with a lock washer
granth   +1y
what exactly do lock washers do?
i think they expand and kinda put pressure on the bolt so it doesnt back off. i dont know
thacru78   +1y
It's a thick washer with a cut in it. The washer is bent a little. Whenever you tighten the nut down the washer becomes flat, but the original bend keep pressure on the nut at all time locking it in. Therefore, it's a lock washer.
nryota   +1y
grade 8 bolts spark real well too!!
granth   +1y
ah, so thats how they work haha. good deal.
BioMax   +1y
If you can, you should ALWAYS use nyloc nuts. There isn't one place on a mini that needs a grade 8 nut (except on the torsion adjusters and you shouldn't have those any more) so a grade 5 nut will be fine. You should definately use grade 8 bolts though.
fyi it is a fullsize. but ok. thanks guys
lx4life   +1y
I am with BioMax you only need Grade 5 and some nylon insert lock nuts. Grade 8's are used for more Commercial and large machinery applications
