Page 1 of 3
Toyota Trucks \  Autozone says alternator is good but battery keeps dying.
Toyota Trucks Make Specific
views 53946
replies 26
following 25
madmatt   +1y
My truck started having trouble starting when I would get in it in the morning. Then it started happening in the evenings too. I thought the alternator was going bad, took it to autozone and it passed their test. I thought maybe it was a drain on the battery, so I started disconnecting the negative battery terminal when I left the truck for long periods. Got in it the other morning and click-click-click it finally started but it spit and sputtered till I reved it up... same this this evening. So, it can't be a draw on the battery? Unless it is so bad that it won't let it charge while it is running, but I have had all the electronics on for about a year and no problems with my wiring job, so I don't see why something like that would happen all of a sudden now.
Any ideas?... thanks!
retro dime   +1y
Starter? Only other thing I can think of.
///RELAXED 720   +1y
i went thru 4 batteries & 3 alternators... before we changed the simplest of things a battery cable.... fixed it right up.... Oh & that happened out of nowhere. Drove fine then all the sudden it started drainin the battery.... just an idea .....
simple-pleasurez   +1y
i had this problem and all i needed to do was tighten the bolt on the starter from the battery. wasnt making enough of a connection. check it out
crochface   +1y
ya ive been having this same problem with my geo
been workin fine for like 5 years
now all of the sudden my battery seems drained every time i get in, it acts like its going to die but hasnt died on me for 4 months, for 4 months it just pretends like its dead. and takes a minute to crank over. even if i just drove it across town and got out for 5 minutes and get back in it still takes a second as if the battery didn't charge while i was driving. alternator is fine. battery is getting a charge too. i was wondering if it was a bad starter or messed up cable.
bowtied   +1y
I work at autozone man, don't believe what they tell you all the time. Some of the guys that do the tests on parts don't have a clue what there doen. Testing it off the car is best (if it's relativly easy to get off). Prolly just a cable like the rest of the guys on here said. Good luck man.
yota93   +1y
did you try running your truck, then take the negtive battery cable off,
Down_To_Earth_Chick   +1y
had the same issue with my wagon. only the alternator was bad. so i replaced it and bought a new battery since i KILLED the other to a bad CELL. Sure enough the starter had something to do with it along with the battery cable....I tried the cheepest thing first to the most exspensive...
It hasn't killed a battery since.
smctoy   +1y
sounds like the cable to me...be sure to check all your grounds & tighten all the cables on the starter!!
TOYZRUS   +1y
I have a trickle charger hooked to mine and it charge's all 4 batteries when it needs it.
