Page 1 of 4
Ford Trucks \  ranger rear end
ranger rear end
Ford Trucks Make Specific
views 598
replies 32
following 19
loweredtillidie   +1y
I jus put the bed on my truck and when its layed completly out the tops of my tires touch the insides of my bedside. I know the obvious thing to do is the have the rear end narrowed, but i only need like 1/2 inch on each side so i was wandering if there is any other things i could do to get the the space i need instead of having the rear end narrowed
nvrdoned50   +1y
swap to a toyota axle...it should be narrower
societyoutkast   +1y
hey i got a mazda rear end will that work
mindlissmetalfab   +1y
Edited: 2/28/2008 6:09:30 PM by iLLblazer
He probably wants to keep the same bolt pattern? Yota should work if it is narrower.
societyoutkast   +1y
Edited: 2/28/2008 6:33:16 PM by society_outkast
o ya forgot about that but isnt the rear realy easy to convert.....i mean shoot i was just throwin it out there LoL
bodydropped85   +1y
yea its narrower. what year ranger do you have? if you dont care for the abs sensor, a gen I(83-8 rear end is narrower then a 93 up. not by much tho.
trenth48   +1y
if your going to go through the trouble of swapping out rear ends wouldn't it be just as easy or easier to have that one narrowed?
Dejavu   +1y
or maybe you could have some machined off the the back sides of your wheels?
dakotahq   +1y
if you only need a 1/2 inch, just pull the bedsides...the offroader's do it all the time... and gain as much as 2 inches...and 1/2 inch would barely be noticeable...
bodydropped85   +1y
yea but his is rubbing were the bed starts to curve in towards the top. i would assume.
