65 ford
15 following
65 ford
4
4doormazda
i just bought a 65 ford from my dad....its all there 352 big block auto with the spot light... i know it has i beams ...my question is if i baged it on the beams and z the frame with the four link and a c notch it should lay correct.. or do i have to buy drop beams or can some one make some custom ones... or should i put a ifs on the front.?? i like the beams cause of the camber and i was wondering about a irs for the rear like a 300zx rear end ... let me know on any info that can help ... i would like to take it to this years truck bash...
THE LOW RANGER's avatar
THE LOW RANGER
clip it with a mustang two suspention less headach then you can stock floor it whill you at it
dhpmike's avatar
dhpmike
Use a Ford Torino A arm clip, much cheaper, larger brakes, sway bar, fits a Ford V-8 well.
I did mine back in the mid 80s, I also did a step notch, although then people said I was nuts for cutting a hole in my bed.
You can cut the curved part of the frame off just under where your feet are, and plate it. then you have the truck laying body with no BD. keep the stock 9 inch. much more options for axles, gears and such. like using two short axles instead of one long and one short, then you have a narrowed rear and only cut one side and all you have to do is buy a wrecking yard short side axle and cut the housing.
or get a disc 9 inch from a lincoln or granada
RatRod1964's avatar
RatRod1964
my truck is a 64 and it had a damn strait axle under it.i put a fat man fab mustang 2 front end under it..damn that shit.. the directions sucked ass.. i still need to Z it to make it lay all the way out.. the frame hangs .75 inch lower than the body on those trucks so not Z'd mine lays like 1.75 from the rocker...
draggincaddy's avatar
draggincaddy
i wouldn't mess with the ol i beams. more trouble than its worth and it would take a retarded z to get it down, even with drop beams. plus if you do a sub swap you get power steerin and power disk brakes with way better handling and camber.
by the time you bag, z, and drop the motor tranny back down you could subframed and bagged the front. i did my 1st one in a weekend ( welded and plated)
dragmatic's avatar
dragmatic
Here are two really good options. You'll have to copy/paste the links but they are worth checking into.
IRS
http://team321.com/truckirs/truckirs.html
IFS
http://www.ford-trucks.com/forums/716058-buildup-06-crown-vic-front-suspension-into-67-f100.html
dragmatic's avatar
dragmatic
BTW..if ANYONE can help me find one of these front suspensions in NC or very close by I would be forever grateful. I've had no luck whatsoever.
dragitall
chris i live in mebane, iv got some old ford pickup stuff, what do you need?
dragmatic's avatar
dragmatic
Hit me up at dragmatic@aol.com with some info on what you've got. I may be interested.
jibee
I had a 1995 F150 bagged before. It didnt lay frame, didnt have the radius arms relocated, nothing too major just because it was my first venture into bagging. But that was 7 years and bout 8 bagged trucks ago. I dont have any concerns about getting involved with bagging this truck I just wasnt sure if this truck needed a Z like the older trucks. Anybody have any info???????
