Page 1 of 3
Mini Truckin General \  dead battery with door poppers oh crap
views 2519
replies 22
following 23
Thisiswhy   +1y
ya you know it all happens i need to have a secondary way to get in what are the manual ones all about
DraggersDreams   +1y
Just use a wire of some sort and run it under the fender
lownoma99   +1y
yea... its up to u where u put the button.ive seen them under wheelwells, back of cab walls, etc. the other thing u might wanna think about is an alternate set of charging terminals that u can mount somewhere else. ive seen them placed in odd locations too... that way u can still jump the truck to get in! hope it helps for the future
XpLower   +1y
what Chad said, I always use a long choke cable and mount under the fender.
iRIDElow   +1y
suck i like the jump terminals
karathos   +1y
I'm with dave up there, I have another positive terminal mounted to my core support. I just put rubber washers on both sides and a rubber bushing around the bolt. This way i have no worries about it grounding out. I've used it probably 4 times. Also you dont need a negitive, because anything metal works well.
laydsuzu   +1y
just put your hood release under the fender....thats what alot of bd trucks have to do, thats what i did to mine....make it hidden of course
chromeridincowboy   +1y
yeah what scooter said. that is how my truck is setup, my hood release is on the back side of the core support right ahead of the front wheels...guess mine isn't hidden anymore
simple-pleasurez   +1y
how about the battery backups you always see in those aim ads. those worth anything?
tuckinlugs06   +1y
what i have rigged up is a spare hood cable run threw the door jab and into the fender...and when they wont pop i just pull the cable and it pops open...
