Page 1 of 4
Mini Truckin General \  Throwing sparks
Throwing sparks
views 2117
replies 35
following 33
The_Dirty_Desperado   +1y
Right now I am dragging trailer hitch balls, I heard i can throw green sparks with magnesium blocks, I just cant find any. Anywone know where I can get some, or anything else cool I can drag??
dflated19   +1y
just bolt on like 10 different metals and tell us which one throws the sweetest sparks. obviously titanium will but maybe u can discover something new! lol
randallss10   +1y
frame
dkadventures   +1y
You can try dragging body or for those less endowed just a little frame
laydsuzu   +1y
body throws great sparks, but i stopped that....after my rockers split...if you drag magnesium, it will immediately catch fire and engulf into flames and catch everything else on fire....titanium goes quick too...its a soft metal...just try flat bar carbon steel...
jcjcsoccerkid   +1y
didnt you take chemistry in high school? magnesium is way too flammable to use for dragging, unless of course you WANT your shit to catch on fire. if thats the case then go ahead. it also makes noxious fumes when it burns.
dragging balls isn't that smart either. just get 1/4" steel welded to your frame.
societyoutkast   +1y
frame is the best
oneup   +1y
plate your frame trailer balls hurt when they come off. If you want different color sparks get a windsheild washer resivour and mount it to spray in front of your drag spot then use different liquids etc it will make diferent color sparks or flames depending on what you use just make sure don't spray to much If you use certain oils mixed with a small amount of kerosene it will actually leave flame trails behind you may not be the safest thing but it does make some pretty sweet shit plus if you make them posable you can turn it to be in front of your tires and spray bleach to do some wicked smoky burn outs
SoDakminis   +1y
wow
bodydropped   +1y
Edited: 6/4/2008 9:56:44 AM by bodydropped
magnisem once it catchs on fire it can never be put out thats why it was outlawed by the government for making wheels out of it, i was running a piece of section 40 pipe filled with titanium which helped make the titanium last longer, but i know that copper wont spark but if you want a bright spark find some zirconium its brighter than titanium but expensive, but now i run about 3 peices of 1/4 flat bar welded together
