f350 turned into a non ibeam
15 following
low95xlt
looking to stockfloor a f350 and dont want a i beam front end since want to run a 24 inch wheel but still be eight lug,, what can i do should i jsut clip it to a chevy front suspension??? and can i adapt the a arms to accept balljoint for ford to go into the ford hub or should i keep it chevy front hub setup?
tlw32882's avatar
tlw32882
just run all chevy. it will eliminate alot of headaches!
stumbledin
your better off adding a full frame clip in the front. Camaro or something like that. if your wanting to get the ford engine to lay down deep in the frame, use a ford car clip.
low95xlt
i was wanting to keep the v-10and stockfloor it jsut concerned about gear box issues and such
low f350's avatar
low f350
Im planning on using a duramax dually front clip. The motormounts will need to be changed and Im planning on using all the chevy steering. I will need to build a new link to the chevy gear box and adapt the hydraboost somehow.
tlw32882's avatar
tlw32882
new motor mounts and work with the chevy steering, shouldnt be to dificult. its gota be better than dealling with i beams, just a thought.
low95xlt
yea that is what i am thinking but now should i find a non dually rear axle to keep the same bolt pattern?
low f350's avatar
low f350
I would use the axle that matches the front setup. On mine Im using adapters for the semi wheels so Im just gonna get the front ones for a chevy and the rear axle will be my dana 80 with the ford pattern.
soccorjimmy's avatar
soccorjimmy
I hear on losin the I beams, I am f going with a yota front clip on my ranger. JIMMY
low95xlt
could i make mounts and jsut use upper and lower a arms from a chevy and still use the hub? and spindle?
