Mini Truckin General \  SFBD BUILDS WERE INTO NOW
views 299
replies 12
following 7
insaneautoconcepts   +1y
Well here are some pics of what we have been working on here at insane. Just let us know how we are doing.
      Ok so I will have to use the other camera now this just takes to small of pics right now. O plus we have a few more to share real soon.
Just wanting to post to you all again. Chassis are going strong and still taking orders. Also working on some new designs for all of you that like tube work.
waynehammer   +1y
now i may be wrong, but i dont think this bar is going to keep the axle from swaying side to side at all with the rod ends mounted like that.. shouldnt the be vertical instead of horizontal. but like i said, i may be wrong. you guys are the builders not me
gonz   +1y
---------------------------------------------Originally posted by Pazz88mazdaThats some sexy curves you got on that frame rail ... is that like a monti carlo rear frame ?--------------------------------------------- looks like just a manderel bent frame.
---------------------------------------------Originally posted by waynehammer
--------------------------------------------- This bar has been something we have done for several several years. It accually comes out of drag racing. We have never had any problem with rear setup.  To all the others yes these are manderal rails and not carlo clips.
AVTekk   +1y
I agree, the track bar setup in the picture looks done right to me, it doesnt matter which way the heims are mounted because there is just tension and compression on them, not any type of side load. The only problem with laying them down like that is youll run out of travel and contact the tabs with a ton of lift.
16" of lift if the shocks are mounted in the correct position. Plus you can get a ton more if you move the bag forward.
dumpednshaved   +1y
Bringing this back in hopes that you will read this but I have sent you an email and tried to get in touch with you with no luck.  If you get this please hit me back on here or in email.
---------------------------------------------Originally posted by dumpednshavedBringing this back in hopes that you will read this but I have sent you an email and tried to get in touch with you with no luck.  If you get this please hit me back on here or in email.--------------------------------------------- Wes I do truly appologise but I have responded to all my emails concerning any frame or products. I also have answered every call or voicemail left. What is it that I can help you with? Do you have my correct email? Siac@knology.net or sean@seriouslyinsaneautoconcepts.com. Either one will reach me.
