--== FREE RENDERING TO THE FIRST PERSON TO FIGURE THIS OUT==--
20 following
crochface avatar
crochface
Edited: 6/4/2009 9:15:58 PM by crochface
i have something draining my battery and i traced the source down to 2 wires. im not sure what they go to and don't know what i should do to fix the drain.
the first person who helps me figure out what is draining the batter will get a free rendering or any art work you want.
i did all the hard work im just hoping someone has seen this problem before and knows what to look for.
in the first picture you can see there is 2 wires that are draining a 12volt current when the battery is connected
in this second picture you can see what fuses those wires connect to to help you understand the diagram. one is connected to the AM1 40A fuse as i labeled #1. the other wire is labeled #5 and is connected to the ALT 100A fuse
now in the picture of the diagram #5 wire is between the battery and the fuse box and looks like it has a wire taping into it thats most likely the source of the drain that wire leads to AM2 in the ignition switch
the other wire i labeled #1runs to the starter relay but AM1 taps into it for the ignition switch
so my prediction is that AM1 and AM2 are both my drain and both are connected to the ignition switch
IS THE IGNITION SWITCH WHATS CAUSING THE DRAIN OR IS IT SOMETHING ELSE. IF IT IS THE IGNITION SWITCH HOW WILL I TEST IT ?
mike86mazda avatar
mike86mazda
did it just start happening all of a sudden? did it start after you did smething?
SoloSpecialties avatar
SoloSpecialties
on what kind of vehicle?
townzenm avatar
townzenm
You can check to see if you are getting power on any of the wires on the right side of the ignition switch. According to the diagram no power should be feeding through there with the ignition off.
2001x avatar
2001x
yeah im with you nick...i got something draining my battery down also
wickedinsides avatar
wickedinsides
following the wiring schematics im gonna say your ignition switch is messed up and is stuck open in accesory or igniton position. what kind of vehicle
wickedinsides
so with the truck off check under the column if your accesory or ignition wire has power. the only thing that should have 12 volts with the truck off and the key not in the cylinder is your constant. in your case am1 and am2
arod84 avatar
arod84
Are you laying out the vehicle on, especially soft ground or most surface?  A friend of mine was storing a bagged dually for someone and it would lose charge everytime we layed it out in the grass, because of the ground wire to the frame and it grounded out to the dirt.  I'm sure there was more wrong with the truck than that but, it was one reason.  It usually went dead within a few hours.
crochface avatar
crochface
 ---------------------------------------------Originally posted by mike91yota did it just start happening all of a sudden? did it start after you did smething? --------------------------------------------- ------>   it started about 2years ago while the vehicle sat outside for a month at mike alexanders house, out of the blue for no reason its never been right since    ---------------------------------------------Originally posted by Pazz88mazda  (drain 1) your Ignition... do you think you could bypass your ignition and go to a temp button ? you should be able to take your main 2 key wires and use a button "tor TEMP"  and if you still  have the drain it will probly be one of the other 4 wires .. like a att. wire  and when you say taped... do you mean stock or someone did it lately  ---------------------------------------------   ------> when i say tapped i mean in the diagram a wire tapps into it and its stock  ---------------------------------------------Originally posted by SoloSpecialtieson what kind of vehicle? ---------------------------------------------  ------>  its my geo prizm    ---------------------------------------------Originally posted by townzenmYou can check to see if you are getting power on any of the wires on the right side of the ignition switch. According to the diagram no power should be feeding through there with the ignition off. --------------------------------------------- ----------> ill try that tomorrow and see what happens, i dont even know what an ignition switch looks like or where to find it.
dajizz avatar
dajizz
Edited: 6/5/2009 1:05:34 AM by dajizzsocal
On your white wire headed to the ign switch (the part right behind the key) the diagram shows it goes from the fuse up to the switch. But also continues on up and off the page. I'd trace that wire down to it's next stop and see what it does. Most likely is the part making it drain. If the key switch is bad, the accys in the car might still be running. But unlikely. look for where the rest of that white wire went. With the key off, use a MULTIMETER, not a test light do measure voltage after that next part.or foe shits and grins, take the multimeter from a good ground again, with the key off, and probe the switch(#4 the black with yellow stripe, #8 the black with white stripe, and #3 black with orange stripe) if there is even a fraction of voltage present at any of these places, you have found the culprit. GOOD LUCK! Ok, just realized what you were saying with the white wire and where it goes. Then check the white wire at the starter relay to see if there is juice passing thru it (same way as above)
