i fried something good
TH
team haymaker
ok after a late night of GTsnowracing i was sitting at a stoplight when my headlights went super bright and shut off, thought to myself, "thats not good" , then looked at my amp guage, (normally running around 13 ithink) and its up at like 70, all my interior lights were like looking at the sun, then my wipers turned on full, signals turned on, and then everything stopped, including the truck, it all shut off, now i have no power to anything except the hazard lights,
what do the mazda gurus think?
my thoughts were the voltage regulator, but im not good with electrical diagnostics, so any help would be amazing,
if it matters, its a 91 b2200, carbed, power nothing (except the seats i put in)
thanks for the time and help in advance
-craig
8
88lx
That is very unusual, so what did those little guy's look like?... Honestly If It were in my presence I might tell ya, but Not right off.
mullet
I would check your fuses.. if you supply too much power than the fuse amperage allows then they will pop. I would take off the alternator and have it checked out and see if the voltage regulator is good (internal on the b2200 alternators). Or maybe the alternator blew out a rectifier diode or something and put out a shit ton of power and then blew fuses. Let me know what you find.. any burnt up wires or what not.
Mike
mullet
O.. also the fusable link to the alternator
TH
team haymaker
will do boss, ill be starting my search and destroy for the cause of this problem thursday night i think, i assumed it had an internal voltage regulator, but ill check fuses before work tomorrow and let you know how they look.
and the alt. is going to be checked out for sure
thanks for the quick replies guys...........this sites great because of people like you
TH
team haymaker
so i went out to check the fuse panel and only 1 fuse is blown, the "engine" fuse, so i swaped it out and now i have power to my interior lights but still nothing else, friday ill be pulling the alternator and checking wiring
speedster93b's avatar
speedster93b
did you check your underhood fuse panel?
nytrdr24's avatar
nytrdr24
have the alternator checked, check all fuses, and wiring for shorts, also might want to look at the wire running from the coil to the dizzy, it could have shorted caused the voltage spike......good luck hope you get it fixed!
8
88lx
since it was mentioned, I'm leaning toward the Alt. regulator and rectifier are a distinct possibility
pancaked
its the reg in the alt. i blew one on the way to heat wave me and russell swapped that shit out in mississippi in a auto parts parking lot it blewmybattery caps off when i popped the hood haha its def the alt man
kia swap
last post by Brody +1y
51
