Page 1 of 3
Mazda Engine General \  whats the easiest engine swap
views 22374
replies 26
following 8
g_money   +1y
i was wondering what other engine could you swap with the 89 b2200 2.2L that would just bolt up? what other engines could i swap that would just drop right in. just for future thoughts
mark   +1y
you can run a complete 626 2.0 motor and it will bolt right up. Same F-series block. You can even get the 626 turbo,
joemazda93   +1y
The motors in the 626 turbo are they the 2.2 turbo and the same as an mx-6 turbo? Wondering if my 2.2 turbo will match up with my 2600's tranny
nytrdr24   +1y
MODEL YEAR ENGINE CC BORE
B2200 8v 1987-93 F2 8v 2184cc 86mm
these will bolt up to the tranny, but you may have to do some mods to the intake, wiring harness, etc....
*mazda*
626 1983-87 FE 1998cc 86mm
B2000 1985-87 FE 1998cc 86mm
626 Turbo 1986-87 FE 1998cc 86mm
626 1988-92 F2 12v 2184cc 86mm
MX6 1988-92 F2 12v 2184cc 86mm
626 Turbo 1988-92 F2 12v 2184cc 86mm
MX6 Turbo 1988-92 F2 12v 2184cc 86mm
*kia*
Sportage 1995-96 FE 1998cc 86mm
Sportage 1995-02 FE 1998cc 86mm
*ford*
Probe 1989-'92 F2 2184cc 86mm
Probe Turbo 1989-'92 F2 2184cc 86mm
those are just the domestic ones, there are a few other engines that mazda put out to other countries that can bolt up too
nytrdr24   +1y
not to a 2600 tranny, different size input shaft on the tranny.....it will bolt to a 2200 tranny.
joemazda93   +1y
thanks for the answer on the mx-6 turbo motor i have one and have been trying to get this question answered for a long time and no one hase ever been able to answer thank god i have a 2200 tranny in mmy garage
nytrdr24   +1y
no prob....i also have seen while searching about my rear axle, that the 99+ miata 6speed trannys come from the same "m" family that the 2200 tranny is from, and might bolt up to our engine too.....would be nice to know if that was the case
joemazda93   +1y
Yeah that is something else to consider seems like that would be scenario if i am to swap the 2.2 turbo
southernrazed   +1y
that would be awsome
joemazda93   +1y
Yeah that would be a 6-speed tubo b-series damn and i have the boost at 15psi while its in my car and it run 14.5 in the 1/4 i should have a pretty speedy truck haha
