Page 1 of 4
Mazda Engine General \  Engine Cuts Off When Stopping
views 2047
replies 30
following 12
lowonair   +1y
I was wondering if anyone else has had this issue with their B2000. This only happens on certain days for some reason. When I take it out of gear and start to brake the RPM's just drop and will stall the motor out if I dont hit the gas pedal before it cuts off completely. If I pull it out of gear and ease to a stop very slowly I can get it not to stall, but a normal or hard stop is almost certain to stall. The next day it will drive fine, shits got me stumped.
Throw in your 2 cents here -->
90b2200   +1y
i have three mazda's and they all do tha same thing. i waz told it waz the distributer.
something with some internal bushings wearing out.
i have yet to figure it out for sure tho.
Peace N|ck
inferno94   +1y
I had a similar issue, changed cap rotor plugs and wires even coil and nada. The carb was outa wack, if you have a dwell meter you can check it, you could be running super lean, I was.
costa   +1y
i have same problem also changed my cap/rotor/plugs/wires/timings good/tried with a holley & a weber carb and the dawg just loves to sleep...got it stored up but after i finish with the interior i got to get back on the troubleshooting because this one is really making me scratch my head... one min its rich the next its lean
dropped90(justin)   +1y
mine use to do it and then i swapped over to a weber and got rid of all the emissions shit and computer and it dont do it anymore
-justin
lowonair   +1y
Interesting....
90b2200   +1y
im running a weber and it still does the same thing.....
Peace N|ck
Cusser   +1y
Check ignitor and pick-up, inside the distributor.
costa   +1y
you think if i just replace the distributor it would help out quite a bit? just i know they arent that cheap
minime   +1y
Check to see if the EGR valve isn't clogged up with carbon. Mine did that for a couple of days till I took it off and cleaned it out.
