Question about rear end
mpenner49
I am putting a 302 in my mazda. Am i gonna be able to use my stock rear end? I heard that these Mazda Rear ends are awsome but awsome enough for a 302? Should I plan on put a diffrent rear end?
pont's avatar
pont
I heard that thay will hold but im not gone risk it im gone put a 8.8 out of a 04 ranger or a mustang if need be ill get one out of a F150 and have it cut down to fit as well. the main reason i dont wont to risk it is if it bust then i got to have the driveshaft remade which i dont feel like paying 2 times for the samething
mpenner49
Is it hard to cut down an axle?? Is it something someone could do or need it sent out?
pont's avatar
pont
you can buy the axle to the length you wont its the axle housing that has to be shorted and you can do it if you know what your doing but im gone send mine off so i know its right the drive line is something i dont wont to take a chance with
mpenner49
What do they shorten? the tubes between the hubs and differential?
pont's avatar
pont
yea thay cut the hub side down and add new flages and berring housing
mullet
and if its a stock 302 you should be fine.. got a friend w/ a 347 and stock rear end.. just can't abuse it. its a half ton rear end.
foesicks's avatar
foesicks
i'm going to use a 87 t.bird rearend on mine b.cause it came with the motor. I also heard I can through explorer axles in it to switch to 5 lug and rear discs all at once, but I don't know if this is true yet
slammed91b5000
it should be fine. i m running a stock mazda rearend, and my 302 is pretty built. i have bagged on it a few times. so far so good. there is too much power and not enuf traction to break it. the wheels just spin, there is no tourque on the rearend to cause damage haha
mpenner49
So it won't bust? Well lets say I wanna beef it up for safety, whats the ebst to use? and most cost effective
