stock gas tank on baggged truck
11 following
low87dawg
hey can i put my tank back behind my tailgate skin and just have the neck come up out of the bed???
mullet
yes.. it will fit in the frame rails.. you might have to cut the floor out and have it flush with the bed floor for clearance issues.. or get a chevy blazer gas tank.. it will fit in there for sure.
minimazda93
if you do that you need to put it half in half out (the mounting holes on the sides of the tank bolted to the bedfloor) because behind the wheels you have to worry about dragging there too when you lift the front dump the back for dragging and whatnot. Honestly the best bet is a fuel cell up against the cab at the front of the bed.
mark
yea, i cut mine out because it would have been too low to make it flush with the bed and just have the neck sti ck out
not the best pic, but you get the idea
and it has to be a standardcab gas tank, the xcab tanks are too long
low87dawg
yea its a reg cab but i might try to find a blazer gas tank and it should be fine right?
mullet
Yeah.. they are a few inches wider and a not as deep.. so they fit under there. Also.. i hear most boat fuel cells will fit too.
low87dawg
does mazda's have a external fuel pump or is it in the tank? please help let me know
mullet
depends.. some of them have it on the side of the engine... i'm not sure if the other one is in or on the tank.
schreff
What year is your truck?
grantkustoms's avatar
grantkustoms
fuel injected motors have it in the gas tank.
