Stumped and idk what to do
hamiltonalex93
Have a 88mazda b2200 and has a rebilt engine and new distrubter and spark plugs. Is getting spark and getting gas and timed and still won't run. Turns over well has great compression and I wanna keep this truck in the family it is my first car and I don't wanna give up on it to please give me some ideas to what to look at.
91extcab's avatar
91extcab
Could be that the distributor is 180 degrees out... Does it pop and backfire when you try to start it...?
dropped90(justin)'s avatar
dropped90(justin)
Yeah man give us a little more information as to what exactly you mean when you say it wont run.....will it not even fire up? will it fire up but run like shit? Does it make funky noises? Little more info and we can give you a better idea on whats going on.
-Justin
hamiltonalex93
It won't hit at all sometimes I get a back fire through the carb but thats the most I get I had it runnin before but found out that the oil pupmp went out and we replaced it then tried to start it again then nothin
91extcab's avatar
91extcab
Did you put the new distributor (as stated in the op) in since the last time it was running... If so, you're probably 180 degrees out on it. I would pull the distributor, make sure you have the engine at top dead center on the compression stroke and line the distributor up where the rotor is pointing to where it would be for cylinder 1 in accordance with the cap. Also make sure that your wires are run to the proper plug locations. Mazdas fire in the order of 1-3-4-2. Now I could be slightly off with firing order since I'm doing this from memory and my book is with a friend about 3 hours away. Anyone feel free to correct me if I'm wrong.
beastbseries
A ur right bro firing order is 1-3-4-2 cause 1&4 and 3&2 are companion pistons and it might be that distributor that is 180 off cuz I had the same problem and I flipped it and I advanced the trimming barley and it started right up with no problem
91extcab's avatar
91extcab
i've been 180 on a couple of engines, including my current 2600i (after the rebuild), and putting the engine at tdc on the compression stroke, and then resetting the distributor always worked. with my 2600i i had to replace the distributor, thought i was at tdc on the comp stroke (was on the exhaust stroke), reset tdc, and reinstalled the distributor and it fired up first shot. no popping, no backfire, just purrrrfect purring of my engine...
91extcab's avatar
91extcab
oh, and welcome to the scene, both hamiltonalex and beastbseries
hamiltonalex93
Thanks and I'm deftinally gonna try it tomorrow it's been forever since I've drove it kinda miss it and the gas milage lol I'll update some time soon
91extcab's avatar
91extcab
hey alex... let me know if you changed the distributor when you did the oil pump... that could atleast help narrow down if you are out on the timing with it or not
