i got it close but somthin aint quite right
mazdafvr
hey guys, I did the 2.0 head swap and put in a set of rings while I was at it and over the last few days after work I been tweakin on it and trying to get the valves set, carb tuned ect. I think I got the valves close, I set to .008 mm and theres still some clatter. but somthin still aint quite right, like sometimes when I rev it, its firing but the motor hesitates just a little, maybe a little sputter here and there at idle. I tweaked all through the carb and that aint it, I found a few vacuum leaks, fixed them, made a bit of a difference. but thers still a miss somers. I was hauling ass thru my field last night and I had my foot down not all the way but a good bit and it stopped accelerating for a few seconds, it was still maintaining speed but just no power then bam! took off again. almost like a plug wasn't firing or a cylinder wasn't getting fuel but it was real quik, like a second. but when its not doing it it seems to run a hell of a lot better than it did. so im getting close. any ideas, I used almost a hole can of starter fluid looking for leaks, the hose that runs from brake master to intake was leaking like hell but I replaced it. thanx in advance
fdugn545's avatar
fdugn545
I'm sure u checked /replaced it but maybe the fuel filter? That's sounds like what mine did when filter was getting plugged. Or maybe bad wires or coil. I had an issue with a brand new set of spark plug wires I bought and two of them were not firing correctly. Idk man I have a miss at idle when cold but once it warms up it runs good.
Sorry I'm not much help...
Fred
Sent from GS2 on Tapatalk
mazdafvr
it barely does it at idle, just I little bitty puff and then I don't here it for another 10 to 20 seconds, more so when im moving, especially under heavier throttle. Ill take a look at the filter, the outside looks bran new but wouldn't hurt, just replaced wires, the were fine b4 I started the swap. I went and waited to do the swap until I had it runnin right then went and messed it up. lol. maybe I still have a valve off but I used a feeler gauge.
fdugn545's avatar
fdugn545
Also I recently adjusted my lifters to the T and they still chatter... Just saying...
Fred
fdugn545's avatar
fdugn545
My filter looked okay from the outside but when I took it out brown shit poured out.
mazdafvr
well, I give it a look later tonight, there aint much else it could be so theres a good chance that might be it.
fdugn545's avatar
fdugn545
Keep us posted man! If I could actually help someone that would make my day!
mazdafvr
ha, yea me too, I try or atleast hope some of the things I post may help others later down the road. ill let u know what it looks like, thanx for the info
mazdafvr
still wonder why I have a lifter or two ticking, I set the gaps at .008 with a feeler gauge
mazdafvr
got to reading valve lash and im seeing the measurements in inches, my feeler gauge is in mm, what mm should it be set to cause I have it at .008
