5 lug conversion
11 following
5 lug conversion
d50got_air
Any1 converted their front hubs to 5 lug from say a Toyota? If so, I need all the details on how you done it.
sideshow
over here we use L300 (mitsu van) hubs, 5 lug and they bolt straight on. and i;m pretty sure there the same as toyota.
anonymous
I havnt done it, but Im also positive the toyota hubs just bolt up to the mitsu drop spindle. I dont believe they will bolt up to a stock spindle, but someone correct me if im wrong.
There are a few guys on here that have done it. So hopefully they will chime in.
d50got_air
How about the bearing and seals? Mitsu or Toyota? Also are all years of the Toyota hubs the same? Or should I look for a particular year.
laidmits
SO DOES ANYONE KNOW IF YOTA HUBS WILL BOLT ON TO THE STOCK SPINDLE? SOMEONE'S GOT TO KNOW.
laidmits
[quote="LAIDMITS
SO DOES ANYONE KNOW IF YOTA HUBS WILL BOLT ON TO THE STOCK SPINDLE? SOMEONE'S GOT TO KNOW.[/quote]
ANYONE, HOW ABOUT STOCK YOTA SPINDLES FITTING ON STOCK MM CONTROL ARMS?
tandem
Check this page. I put in detail how I converted mine.
laidmits
thanx tandem, i saw your post yesterday after i posted here. i'm still wondering if the stock yota spindle fits mm arms. i may be getting a yota
rearend and the guy has the spindles too. so i wanted to know if i should get them too.
tandem
I didn't bother w/ the Yota spindles on mine b/c I already had drop spindles. I'm not sure if the ball joints are the same. I've not heard anything about them.
laidmits
how about the yota hubs working on the stock mm spindle?
btw thanx for the response.
Related Discussions in Max Suspension
