Page 1 of 3
Yota Lowering \  ****Well here is a first****
Yota Lowering Yota Suspension Yota Tech
views 3657
replies 22
following 6
dead_red88   +1y
I have browsed this entire suspension section and now where did I see anything about lifting. Don't give me any crap because i have a fullsize that is deeply going under some reconstruction. Anywho how would i lift my 88 single cab 2wd toyota in the front. Do i need to buy upper control arms since the stockers will hitt the frame after a certain height? In the rear I am just going to ad some leaf's from a 4x4 truck. Help!And if i do need to get some new control arms where do I get them, and if i can go a cheaper route lifting it what do I do?
vegasyota94   +1y
tried the torsion bars?
twisted minis   +1y
Lifting a 4wd is simple. Straight axle it. Its not even hard.
2fine89   +1y
Cranking the torsion bars is the only simple-cheap way of a "minimal" lift. you can get upgraded (larger) torsion bars and new upper controll arms for a little more. there are many companies that make lift components for 2WD toys.
dead_red88   +1y
what are some of the companies (cheap) names?? for the 2wd front suspension.
m_i_zombie   +1y
are you trying to get a pre-runner type lift from this ??
dead_red88   +1y
no like 2-6 something like thaT!!!!
m_i_zombie   +1y
Downey and others make complete kits but cheap they are not. Best bet would be get 4x4 parts truck and modify the arms to fit the 2wd frame. I can get you pics comparing the 2wd and 4wd set up differences.
twisted minis   +1y
No. Go get a 4WD parts truck, and cut the 2WD shit off the frame, and weld on the 4WD crap. The frames are the same, different front suspension.
dead_red88   +1y
well how much lift will i get from just tightening the torsion bars?
