shaving handals and warping doors
23 following
lowgmc94@yahoo.com's avatar
loweredfullsize94's avatar
loweredfullsize94
does anyone know if u can shave handals without caving in ur doors it was my first time and i took my time and let everything cool b4 i moved on and wow i could go swimming in my doors the size of the dent
Drag-N-Low's avatar
Drag-N-Low
man I dont know how people warp there doors so bad, put the welder on a low setting and go slow.
LOWLIFE's avatar
LOWLIFE
go slow and keep a damp cloth with you to keep the temp low. and be careful on the grinding too, you can warp em w/ the grinder!
DBLT8K's avatar
DBLT8K
i agree with both reponses i managed to do mine with out warping them too bad they are gonna warp no matter what you do
madmike's avatar
madmike
i like to use compressed air to cool it, but i might do about 3-4 tacks in as far apart places as posible then cool it till its cold not warm, and as far as grinding goes.... ive learned the hard was that will warp shit fasted then a weld lol, i also use the same method grind for a moment then cool till cold.... use flap discs they be bad ass
for the warp you can try to heat the area with a torch then shock it with cold water to bring it back up, ive never tried this but my buddy told me about him doing that, he is a union sheet metal finisher and works only with stainless tho
mtm's avatar
mtm
anarchyrulez's avatar
anarchyrulez
i do a small tack every 2 inches and go back and fill in the rest of the metal with small wleds in differnet areas so i don`t build heat and wrap metal
using a blow gun to cool it off works good too
flameds10(tyler)'s avatar
flameds10(tyler)
i never have a problem when i shave door handleswhen u are shaving them do u actually cut the old structure out? i always leave it in for support
flameds10(tyler)
glevere's avatar
glevere
Go slow. Use small tack welds spaced apart. Feel the surrounding metal as you go. It will take a while. If its too hot to touch, go to the other side and do that handle while the first one cool. Like they said above, you can warp them with the grinder too. Break out the hammer and dolly to tame those waves...
