Page 1 of 3
Air Ride Suspensions \  front bag mounts parallel? ride or dumped
Air Ride Suspensions Q & A
views 389
replies 27
following 23
Marshkid1   +1y
So should the front upper and lower bag mounts be parallel at ride height or fully dumped. 87 mazda b2k-mike
urdaddy   +1y
you dont want your bags to pinch or twist when deflaited.
twisteddragger   +1y
At ride height. If not the two bellows will rub each other as you drive and can cause failure. You wont dump the truck in a full year to cause as much rubbing as one day of driving with a lopsided bag.
Marshkid1   +1y
sounds like i got two completely different replies
3day   +1y
when the bags are dumped, the top and bottoms should be even, if they arent, they will pinch and you will wear a hole in the bellow after time.
Severed701   +1y
if set up carefully u can get it so the bag is compressed even when dumped...even when at ride height..and a little angled at full lift...this may require your brackets to be a little angled...just takes some pre fitting and measuring
EMPIRE LTD   +1y
--------------------------HAHAHA
mikewendt   +1y
I say parallel when dump
Marshkid1   +1y
i still don't know who to trust in
twisteddragger   +1y
I have had my bags for 5 years and they have been on two different trucks. And they are firestones. Trust who you want.
