Chevy/GMC Trucks \  v8 swap in s-10, sheetmetal firewall
views 406
replies 17
following 9
sjudd86   +1y
Whats up everybody, ive been reading the conversion manual for the v8 swap and cant figure out the transmission. I want keep a 4 speed or 5 speed in my truck, but it says not to use the stock transmission and the only one they refer to really, is the camaro t-5, What transmissions are you guys using in you s-10s, im body dropping it to the rocker as well. also in the october issue of sport truck they did a swap and sheetmetaled the whole firewall. I want to shave my firewall completly but i dont know what to do about the brake booster and shit like that, as of right now im getting a smaller one so my 20s will fit but would much rather get rid of the bitch. do they make something so i can still keep power brakes. any help would be appreciated , im ready to tear into the bastard. thanks alot
SteveForePlay
Iownissan   +1y
personally, i'd go with an automatic that way you dont have to worry about the clutch master cylinder being in the way. most people use the TH350 or Th400 turbo tranny.
TC29720   +1y
What motor do you have in originally?
mtg 89   +1y
Just buy mine the hard stuff is done 1995 boddydropped,bagged,with a BLOWN 350
draggindimes   +1y
i wouldnt use a th400, thats a massive tranny to try and squeeze into an S-10. most people use a either a TH350 or a 700R4. the 700 is probably a little stronger if your lookin to be racing. but either of those two would work. as for your brakes i know there is a hydro-boost set-up out there that is small enough where it can be bolted to the frame. i dont remember the company that makes it but some research could help you find it
bdroppeddak   +1y
th350 is stronger than a 700r4 the 700 has overdrive though, if your truck came with a 4.3 you should be able to use the 5spd tranny.
sjudd86   +1y
ok sorry if im not replying quickly, im out working on my truck. the motor that i had in it was the 2.5 4 cylinder. the only reason i wanted the 5 speed is because thats all i know. But if you guys are suggesting an automatic thats what i will probaly do, whats all involved in switching it over. im clueless as far as that goes. and thanks about the hydro boost deal, i will look that up when i get a chance , sounds like a good alternative. thanks again for your comments.
sjudd86   +1y
was this hyro boost you are talking about made by wilwood?
insaneautoconcepts   +1y
No try www.hydroboost.com I am starting today going to start to put a Hydroboost kit together for the s-10 and yota guys you might want to check with me later. I will know something in a week or so. If your interested.
FASTBAGDHOMBRE   +1y
Hey I am doing this to mine right now!!!! What I did was cut out the whole firewall with the exception of a strip where the brake booster and steering shaft comes through, and I worked from there out and tubbed it out to what looks like could clear a 22 but I am using a booster off of a box blazer so unless they make a 22x8 I'm out of luck (LOL).I have a 350 that is mated to a 700r4. No probs whatsoever....but you will have to buy the lockup kit from Painless if you so happen to get a trans with a lockup torque conv....otherwise you'll mess up the trans! You didnt say what year s-10 but I am assuming it's a box....I have a 96 Hombre and all I had to do was have my driveshaft shortened almost three inches and I didn't even have to change the yoke because both the stock 5 spd for my year and a 700r4 have the same number of splines on the output shaft....Hope this helps...any other ques. email me... FASTBAGDHOMBRE@aol.com
