Foreign Cars (honda, etc) \  Honda Engines D15B7 and D15B2
views 1081
replies 11
following 5
Sawed Up   +1y
I own a 93 honda civic hb and it has a D15B7 (93 Civic) engine in it witch is original...there is a knock in the bottom end and i have considered dropping a D15B2 in(88 Civic) My question is will all the original fuel injection and computer from the 93 bolt right on and work well?
Sawed Up   +1y
If not what would it involve to make it work?
DodgeRT   +1y
prolly not,are they the same OBD?
i'd ditch the crap d-series and go with a b-series,if not the vtec edition go with a ls,gs,or rs b18a or b,or crv motor b20
or a 1 gen integra motor.worth your while if you ask me,
95lowtide   +1y
if you dont have alot of cash, go with a D16z6 1.6L SOHC VTEC motor. it drops right in. your just gonna need the ecu and wire up the VTEC. you should be able to get one for a few hundred bucks at a local junkyard.
Josh..why would he want to get a 1st Gen Integra motor??? that D-series motor is crap. unless you are talking about a 2nd Gen Integra that has the B18a1?
Sawed Up   +1y
They are not the same body style...
1lowastro   +1y
what years and hondas did the Z6 come in stock?? i know the 92-95 civic's and del sol's had them in the SI models, is that all??
95lowtide   +1y
the D16z6 was available in 92-95 Civic Si and EX models and the DelSol Si
1lowastro   +1y
thanks brain, i think thats what my buddys 95 HB needs.
Sawed Up   +1y
What is the diference from B7 to B2?
95lowtide   +1y
not a problem Blake
Sawed Up- the D15b2 is rated 92hp@6000 rpm with 89 ft/lbs tq@4500 rpm, 9.2:1 compression ratio and is non-VTEC and is obd0. the D15b7 has 102hp@5900 rpm with 98 ft/lbs tq@5000 rpm, 9.2:1 compression ratio and is non-VTEC and is obd1. more engine info located here: http://www.hondaswap.com/forums/index.php?showtopic=29825
