Question for russ-d or anyone else
13 following
E
CENCAL559
i have a mazda b2200 and i think the fuel filter is clogged up or something cuz when i drive my truck the check engine light comes on and when i push on the gas it kinda bogs down, i change the gas from cheap gas to chevron and it still does the same if its the fuel filter where is it at and how do i change it
krazeryn
Edited: 10/19/2005 4:26:22 PM by krazeryn
I belive there is a small white/clear plastic inline fuel filter in the engine compartment. Follow the fuel lines and you'll find it. There is also a filter sock in the gas tank that may need to be replaced.
CustomParts's avatar
CustomParts
Its on the passenger side fenderwell. Sounds like your problem.
CENCAL559
thanx
CENCAL559
wut color is it or wut does it look like?
CustomParts
Its round and sorta milky colored
CENCAL559
is it black?
drpdmazda
it should be white, or slightly discolored, find the fuel pump near the carb, then follow the fuel lines towards the passengers fender well, it is held in place with a round metal clip near the fire wall close to the fender, it could be black if someone put an aftermarket one there
minitruckpunk
Looks like this
CENCAL559
mines fuel injected, it looks like a black can and on the top it says out, and on the bottom it has a line that goes towards intake manifold, im almost sure thats it, mines a 90 mazda b2200 if that makes any difference
