Ranger wont start, need help
bagged92
My truck wont start, it was runninig fine until the other day i was backing out of the driveway, and my foot slipped off the clutch and i choked down, and i went to crank it back up but nothing, the truck has power and everything, it will jump start, im just lost, i thought it may be a starter so i got another one but still nothing, could it be the ignition switch, or a fuse for the ignition, if so, where is the fuse, is it under the hood or on the side of the dash, none of the covers have any info on which fuse does what, i know somebody on here knows, thanks
BAGD RANGER's avatar
BAGD RANGER
CHECK YOUR PASSENGER SIDE KICK PANEL BEHIND THERE -- THERE SHOULD BE A INERTIA SWITCH -- ITS A RED BUTTON -- PUSH IT DOWN -- AND THEN YOUR TRUCK SHOULD CRANK RIGHT ON UP --- TRY IT IT MIGHT WORK ----IF NOT IM LOST ---- JAMES HELP THE GUY OUT ---
lowdyme's avatar
lowdyme
ok since it jump start( i asume by using cables) its not that starter it could be a battery or a fuse like you said there are usually fuses in the dash most of the time they are on the drivers side below the column just check them all and replace all burnt ones
bagged92
ill tyr and see if i see the red button, and by jump start i meant push start, sorry for the confusion, thanks, and also if it helps, it a 96 ranger
1 LoWfUKn RaM's avatar
1 LoWfUKn RaM
fuel cut off..........red swtich like they say
bodydropped85's avatar
bodydropped85
it cant be the fuel cut off if he can push start it and it run. check and make sure the clutch pedal switch isnt unplugged.
bagged92
Well i got out there yesterady and checked the fuses, and found two that were blown, they were two of the little fuses on the side of the dash, so i replaced them and the truck tried to turn over, but just cliked like the battery was dead, so i checked the batt with a volt meter and it had about 12.5 volts, so im guessin the battery is good, so i pushed it off, let it run for a while, and turned it off and tried to recrank it, and the motor kinda turned over then started clickin, so i try it again and the two fuses blew again, so what could it be, a guy at my work said rangers are bad about messing up starter relays, could that be it, im lost, james if you have any idea, or any body else, please help
bodydropped85
yea id change the starter solnoid and put in new fuses. what do the fuses go to?
bagged92
Thats the thing, the piece that covers the fuses says nothing, and i looked through the haynes book at advanced, but i didnt see any diagrams,
SuperchargedS10's avatar
SuperchargedS10
there is a relay but if it turns over at all its not that the relay is located up on the firwall pass. side try tapping on the solenoid a couple times and then turn it over sometimes when the solenoid goes out you can get it to turn over that way or try to jump a wire from one post to the other same deal if it turns over the solenoid is your problem
