Vibration in truck
streetsourcemag.com@punk.co.za's avatar
Vibration in truck
xcpointx's avatar
xcpointx
I've got a slight to moderate vibration throughout the cab.. It feels like it could be a loose engine or exhaust mounting but I haven't been able to find anything.
Any other ideas or points to check?
THE LOW RANGER's avatar
THE LOW RANGER
check your drive line and u joints i had the same thing happen to me could be you out of balance hope that helps
xcpointx's avatar
xcpointx
Edited: 12/23/2008 6:36:10 AM by xcpointx
Edited: 12/23/2008 6:35:27 AM by xcpointx
Thanks!Which joints do you mean?
The vibe is easily felt when I rev it in neutral.
jdm customs's avatar
jdm customs
in neutral and not moving? if so, check the motor mounts first.
doulovemins's avatar
doulovemins
could be warped rotors
xcpointx's avatar
xcpointx
Excuse my ignorance here, sorry. What are rotors? Im in south africa so maybe the terminology is different..
I took the truck to the shop yesterday and they guessed at the flywheel being out of balance. Does that sound possible?
Also would a vibration like this also be caused by the timing being out, like if the belt has skipped a tooth?
The vibration is most evident at a certain low rev around 2000. Everything starts shaking.
xcpointx's avatar
xcpointx
bump
fitbmx180's avatar
fitbmx180
Edited: 12/29/2008 9:15:38 AM by fitbmx180
rotors are used on your brakes.. on a mazda.. it would be your front brakes.. it would be what the brake pads catchs on.... and on my one mazda.. it does the same when i reach about 90 km/h
xcpointx's avatar
xcpointx
Oh ok cool, thanks! Ive got this vibration at idle.
Ive checked the timing and it seems fine. However it looks like its HALF a tooth out when I check with a light? Is that possible? At rest crank and cam line up perfectly.
drgnaccordwgn
try mazdabscene.com and mazdatruckin.com , those ppl r great and willing to help....
