Page 1 of 12
Dually Projects \  Canadian built... Project Dool-Eh!... Lots of pics
Dually Projects
views 27919
replies 113
following 52
90yota   +1y
Hey everyone, my names Chris and this is the build of my 85 crew cab long bed SRW that I'm switching over to DRW. Gonna be bagged and stockfloored on 22" Alcoas. Also the bed will be shortened 12" to become a "medium" 7ft bed. Drivetrain planned is a carbed 383 stroker but the more I read into the various LS swaps, the more I'm opening up my mind to going that route. All work will be performed by myself and a few friends/club members in my 16'x20' garage. Everyone likes pics so hopefully I don't screw this up... Enjoy!
The day I picked her up
Wheels I picked up
Before the tear down and a look at My other trucks
Adapters courtesy of Trevor a Tennessee wheel and tire
Tear down begins
Removed bed and sent off for scrap... I'll have to track a good one down when I need one
Tear down
Engine out
Suspension removed...under all the grease and oil, the frame was on great shape
Cab off
Frame out
Cab parked outside next to my toy
Frame stripped
Post was last edited on Mar 04, 2013 08:03. This post has been edited 4 times.
90yota   +1y
A small blueprint that I whipped up for the rear backhalf... Going with a parallel 4link with a watts and bags under the notch
Measuring for the Z... 4.5" up and 1" forward
Cut away
Tacked back up
Material for the new frame rails... Went with 4"x3" 1/4" wall tube
Drew up an actual full size blueprint so I could make sure everything was right
New rails started
Weld porn... All joints were prepped and beveled to insure proper penetration
More welding
Done
Fitting the new rails under the cab
More fitting
New rails in with the bottom of the stock frame cut off
More... I had to keep the section of stock frame so I could locate the new rear body mounts
Started plating and welding up the front frame transition
More welding
Plating up the inside
Filler plate tacked in
Smoothed out
Other side
Welding the new frame to the old
90yota   +1y
Drew up some plates for the rear cab mounts
You get the idea
Boxed and welded
More weld porn
I still need to drill the holes and finish welding when I rotate the frame on its side
Cleaned up all the other cab mounts and started welding them on
Starting to look cleaner
More
Started trans crossmember
More
Welding
More weld porn for ya
Building the 4link pieces
Threading the bars with 1 1/8" threads... All machine work is done by a good friend of mine
Perfect fit
Bars all tacked up and ready for mock up
I drew up all the 4link tabs and my buddy burned em out for me
Ready for test fittin
Mockin up
Getting wider
Which brings me up to the present... I've started building the front 4link crossmember and should get that in this week so I can weld up all the link tabs
iarodder   +1y
WOW! Just WOW, the work is superb looks awesome. I'm a weld engineering tech and those are weld porn........lol very nice weldin! You definately got my attention, keep the photos comin. Welcome to the site by the way.
john-e bravada   +1y
Very nice! I like the up and out on the Z. I was planning that for mine. Is 1" out the magic number?
90yota   +1y
I think it might take a bit more than 1" to get the wheels perfectly centred but at least it'll help.
Thanks for the props guys!
75dually   +1y
You are building a killer ride! Yeah I like the welds, if your not busy over the winter... You could come down to Texas... We will feed you lots of good food... In trade for your welding! Seriously I think you are going to have a ton of fun with that ride. What engine are you going to drop in it?
bk2life   +1y
Yeah the up and forward is nice, makes room for motor and exhaust etc.
Or when you make your new upper and lower control arms you move the spindle forward an inch to do the same.
b dime   +1y
so the z in the front would be one inch backwards?
leedogg   +1y
Killer entrance! Nice work man!
