Page 1 of 9
Mazda Lowering Static \  help with my 4 link??
views 16998
replies 84
following 13
low87dawg   +1y
okay i just bought the whole bag bracket kit from SD with notches and all that stuff
and i am going to buy a 4-link from them and a air management kit from them but i have never bagged a truck before and im not sure how long i need to tell them to build the link bars???
whynotfab   +1y
Your best bet would be to remove your bed, and measure very carefully.
Set the truck at ride height, and figure out what type of front/lower brackets you'd be using (a crossmember, new hangers on the inside) and measure from a point there to the center of the underside of the axle. I usually drop the tape down 2" to consider in the tabs.
For your upper bars, they need to be as triangulated as possible.. Figure out where you'll be mounting the tabs for those, and measure from a point where the holes on the tabs would be, to the center of the axle. Make sure everything clears your bags, etc.
For help with knowing how far out the tabs will stick, so you can measure better:
Measures 2.25" from end to center of the hole.
Measures 4.25" from end to center of the hole.
2.75" from inner part of the arch, to the center of the hole.
2-5/8" from inner part of the arch, to the center of the hole.
So just take those lengths into consideration, and be sure to order all 4 of your bars adjustable so you have a little room for small measurement error, and can adjust your pinion once its all welded up.
As for the actual install *REMEMBER* Measure twice (or 5 times) and cut once , set the truck at ride height, and set the pinion. Bolt your tabs to the bars, might have to trim/grind a little on some.. and sit the bars in place how you planned. Get both sides symmetrical and all your measurements perfect so both sides match, and tack it. Jack the truck up and down as far as a bag would extend, from laid out, while checking the pinion throughout the motion with an angle finder. If it doesnt change, and if anything..maybe 1 degree both ways.. your good to go, weld it all up damn good..
Sorry for the long ass reply, and I have one other idea you might think sounds crazy.. use some cardboard wrapping paper type tubes, and cardboard tabs lol.. duct tape stuff together and mock it up for measurements LOL.
What type of bag brackets are you going with? Well I hope I helped somewhat in all that rambling.. Im usually on aim, so hit me up if you got more questions: WhyNotFab
Good luck!
low87dawg   +1y
i was thinking about baggin right over the axle
whynotfab   +1y
You can do that, just make sure the bars clear your brackets and bags. OR, a great idea would be to use these:
baha   +1y
A safe way to determine the length is to measure from your axle to your front leaf spring perch and have them made to that length.
eksessivdragger   +1y
if he does that, then i hope he doesn't plan on mounting them to the stock from leaf perchs bc he'll drag them off. mazdas the leaf perch hangs lower than the frame. So dont mount them to the leaf perchs in front or back, just cut the perchs off completely when u link it
blare   +1y
You can drill some new holes into the leaf spring perches closer toward the axle. Thats what i was planning on doing
eksessivdragger   +1y
just be carefull when u drag tho. id rather make a new Xmember and mount the bars to them instead of running them to the perches..........just me tho
tskb2200   +1y
yea running in the leaf sping perches might be ok if your body droped but not a good idea if you wanna lay frame. jsut my 2¢
low87dawg   +1y
so i could make them the same lenght as the pirches but no way im gonna put them on there my friend did that on his s-10 and he has like half a bolt left im choppin them ugly things off, but where i put my triangulated part where should i do that ??
or measure i mean o yea and im baggin over axle if that helps
