Page 1 of 6
Mazda Projects \  Doin a fullsize (Project F1 FIDY)...
Mazda Projects
views 5483
replies 58
following 13
maztang (ryan)   +1y
Hey guys, I have been out of here for a little while. Been very...very busy lately. I got a rendering of my 04 F1FIDY by Nick over at Surface DVD while I was in Afghanistan and now it is starting to come together now that I am back home. Plans are a simple bag job, paint job and interior needs to be reupholstered. Trying to work 5 days a week and do things with the family makes it hard to touch the truck but it will get there. On to the pics...
Rendering
Started a center console to house two JL 10W0
Shaved the F150 off the tailgate
C notches
Got the tank and valves mounted
Post was last edited on Aug 10, 2010 02:08. This post has been edited 2 times.
maztang (ryan)   +1y
More to come later, the truck is in the garage ripped apart. I got the leaf springs off and the 4 link and panhard bar are about to go on. I've run all the airlines for the rear and all the wiring. I am setting the rearend up to lay out on a 36" tall tire and the front will only be able to lay out of a 24 3/4" tire without a ton of work. I am trying to keep it simple for a daily. Right now plans on wheels are 24s in the rear and 22s in the front. My components consist of this list
4 Slam Specialties RE8s
2 Viair 444s
4 - 1/2" SMC Valves
4 - 1/4" SMC Valves
1/2" DOT airline - until I can hardline it all
4 Rocker switches
4 1/2" SMC Check valves
2 SMC water traps
Parrallel 4 Link with a panhard bar
2 AVS dual needle 200 psi gauges
1 AVS single needle 200 psi gauge
5 gal. 9 port with drain aluminum tank from AVS
90-b22dawg [andrew]   +1y
if you blan on dbing it i wouldn't go to crazy with the center console build just yet
paparoach1983   +1y
COOL COOL MAN
v8mazda4ever   +1y
nice start on the truck and danm thats a big notch whats the hieght inner on that one
bgdb26k   +1y
Lookin good Ryan!!
maztang (ryan)   +1y
Thanks guys, it's a 10" notch, the way the frame was built is crazy as hell and I wanted to lay on a meaty tire so I went with a big notch. Probably bigger than it needs to be but oh well. haha
toddluck   +1y
dang with that notch you could lay out on semi truck wheels
maztang (ryan)   +1y
yeah, it's big. like i said though, the frame on these trucks are insane and i wanted to lay on a big tire in the rear. i plan on going with 24" wheel in the rear and i also want a meaty tire, probably could have still done that with an 8" notch but wasn't sure. it's all good though, it will still work just fine.
modplant   +1y
Looking good man, let us know if you need anything!
