Page 1 of 5
Mazda 2.2L \  how to remove flywheel... engine turning..
views 5003
replies 41
following 10
matt88brewer   +1y
I think my flywheel bolts are leaking oil... I failed to put thread sealant on them...but when I try to turn them off the engine just spins... how do I keep it from turning.. I dont own an air ratchet...
jacob_tamblin   +1y
or rear main... how do flywheel bolts leak?
sincitylocal   +1y
Remove a spark plug and feed a few feet of 1/4 inch cotton rope into the cylinder. When the piston compresses it, the motor stops turning.
To remove it, just turn the crank back the other way.
Cusser   +1y
I don't have an air compressor either (space limitations), but I do have a 1/2 inch electric impact from Harbor Freight, about 15 years now, about $40. I used it today to remove the wheel lugs on my Frontier so I could check the brake pad thickness.
If you can loosen 2 of the bolts, you could wedge an angle iron using two partially-loosened bolts to prevent the engine from turning. Or drill holes in such angle iron as necessary. You could also likely bend some steel and drill a hole to mount it, and use the two ends of the steel to wedge into the flywheel teeth.
matt88brewer   +1y
Fly wheel bolts leak because they go into the engine where oil
89mazdalade   +1y
to me but that dont sound right i cant recall on mine but i think there sealed (wouldnt make sense oil would always be on the back side of the bolts there for working there way threw the treads and therefore backing out overtime). i just put lock tight on mine no leaks
89mazdalade   +1y
also quick trick my mechanic showed me to break a bolt loose get ur ratchet (preferably a good one) shallow socket put it on the bolt hold the ratcheting head of the ratchet smack the end of the ratchet with a hammer breaks em loos every-time and ps i would never put anything in the teeth of the fly wheel thats shade tree mechanic crap good way to break a tooth
matt88brewer   +1y
I am hearing some people say no sealant is necessary and others say its a must.im gonna pull this flywheel off and if theres oil coming out around thd bolts then im gonna say theyre correct.lol.
matt88brewer   +1y
it kinda makes sense that these bolts would need a thread sealant being that theres 40 to 80 pounds of pressure inside wanting to get out... lol . without the bolts theres a clear passage to the pressurized fluid
89mazdalade   +1y
thats whats up guess so i used blue lock tight on mine gonna get under there tomorrow and look threw the inspection plate see if i see any oil i know its not dripping oil just wanna check
